Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: Allis HD 4 fuel/oil
[Return to Forum]
Kevin Roberts
06-27-2012 11:26:51
67.142.175.21
Just got my injection pump rebuilt and back on the machine and had ran it maybe 1 1/2 hours or so when she started pouring out the black smoke and then I noticed alot of wet oily on the ground when backing out of dirt pile. Looks, feels and smells like fuel and oil. Liquid on dipstick very thin and low, Had checked oil before I started and was black and full.I am afraid to run it to see where the wet is coming from and can't seem to find it with her shut down. Could it be the seals on injection pump shaft? Is the liquid in belly pan coming from a blow by tube? Just not sure. I didn't install the pump myself, so not sure about the seals. Worst thing is she is setting cross ways in my driveway
[Reply]   [No Email]
jm.
06-27-2012 14:43:09
99.196.0.57
 Re: Allis HD 4 fuel/oil in reply to Kevin Roberts, 06-27-2012 11:26:51
You got it ..desiel going into the oilpan then got so full it forced it out. Luck you caught it before it wiped out the engine or caught on fire.
Easy check is drain the crankcase. Fill with some good clean used oil if you have it run it again for 20 minutes and check and see if it is not gaining in the oil pan.
[Reply]  [No Email]
Kevin Roberts
06-27-2012 16:13:16
67.142.175.25
 Re: Allis HD 4 fuel/oil in reply to jm., 06-27-2012 14:43:09
Is the most likely culprit the o-rings on the shaft? I called the guy that installed it and he said he had some trouble sliding them on, so I am guessing that's the problem. He used some 30 wt oil and the book says to use grease. Could the oil have damaged them?
[Reply]  [No Email]
jm.
06-28-2012 11:42:19
75.105.64.53
 Re: Allis HD 4 fuel/oil in reply to Kevin Roberts, 06-27-2012 16:13:16
Well first we nned to know how old the unit is or what engine..If the unit has a ac motor then he could have roled the cup seal on the drive shaft for the pump. Pretty common thing.
[Reply]  [No Email]
Kevin Roberts
06-28-2012 14:17:11
67.142.175.25
 Re: Allis HD 4 fuel/oil in reply to jm., 06-28-2012 11:42:19
AC 200. I am pretty sure that is what happened. He said he forced the seals the last little bit when he slid pump on. I have also been informed that the return line should have been blown clean or that could have caused them to leak with the higher pressure from rebuilt pump. Thanks.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
