Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Old flat head 6
DGH
06-25-2012 21:18:28
Found an old flat head six. It has the distributor coming out the top of the head. Any idea what engine this might be?
Doug - Iowa
06-29-2012 15:25:27
 Re: Old flat head 6 in reply to DGH, 06-25-2012 21:18:28
Likely a Contenintal Super Hurricane. Used in Jeep FC170. I have one and a manual if you need info, just email me.
jm.
06-26-2012 18:17:12
226 continental and I think the 4 cyl version of the same engine was the 134 but Probably more of that old engine in old equipment than anythin else. Firing order should be cast in to the head and the distributor will be held down by a small clip that most likely wil have a pan head type scre as opposed to a 7/16 boldt. Up draft carb on the side .
DGH
06-26-2012 20:21:20
 Re: Old flat head 6 in reply to jm., 06-26-2012 18:17:12
Yes I think it is the 226 continental. I did see the firing order cast in the head.
Thanks to all for there input.
D7fever
06-26-2012 18:08:59
Hudson, Continental. Hudson had dipper connecting rod lubrication,only 3 main bearings. I think Continental had pumped lube.
Hoss in me
06-26-2012 17:50:36
31 Pontiac had dist. right tween heads smack dab in middle of the eng. I gots one Hoss
Tom Spivak
06-26-2012 14:45:47
My old Otis Baker forklift has a flat head continental, worn right out but always starts and keeps the bugs away in spring.
Tough old engine.
Fritz Maurer
06-25-2012 21:43:09
How about a 6BZ Waukesha?
shinnery
06-25-2012 21:35:56
A Continental of some sort. AFAIK they were the only one that put the distributor thru the head. Only one I ever worked with was in a mid to early 60s Checker Taxi. When they got new 65 Checkers they came with GM 6s. They were too new for me to get to drive one of them.
Bryce
This post was edited by shinnery at 21:37:39 06/25/12.
Copyright © 1997-2015 Yesterday's Tractor Co.
