TractorLinks.com
Re: operating a case 1150 dozer
NCWayne
06-25-2012 11:24:24
Sounds like either the transmission pump has gone out, or one or more of the piston seals on the transmission clutch packs have blown out. Both will cause the pressure to drop. Usually a piston seal will cause one direction, or gear, to stop working while the pump causes everything to stop. In this case it sounds more like the pump, to me, than anything but the only way to know for sure what the problem is will be to pressure check it. Unfortunately I've never worked on one of those so I don't have a clue where to tell you to look for the guage ports to check it. Good luck.
