TractorLinks.com
Re: int 125e tracks
jm.
06-13-2012 18:53:15
Tim the other two have pretty well covered it. If the rails have internal wear too the point that the adjustment is out you might get 250 hrs by removing ONE link but you will need to leave the worn sprockets on the machine. New sprockets on the worn rails just don,t work. I have never seen one that was worn enough to remove two links. Your smoke could be, rings, low compression, weak injector, ect. I thought you had already purchased the unit. LOW oil preasure and destroying the lower (crankshaft) is the only real alibi that the 125 had. When you go to looking for rails TD 8e and some 8C rails will also fit. New off brand rails are avl..
