Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: D8 13A PONY TROUBLE
[Return to Forum]
crazytractor
06-11-2012 20:29:40
67.10.84.248
Well i finially got the pony runing , well momentarily. I replaced the spark pulgs, and condenser, and polished the rotor and points. And started after a few tries. it started loud, but very strong and smooth. I got to turrining the enging, and after about two minutes it started back firing really loud and then shut off. the pony motor trans was leaking oil from a gasket so i will have to remake the gasket befor trying again. I know it can either be fuel or timing, but it was running really good before it shut off so i dnt think it was timming. It was so hot this saturday here in south texas that i didnt even check if it ran out of fuel. I check my spark plugs and they were dirt after small run. they were new. who knows why? what kind of oil does pont trans use incase it leaks out while changing gasket?
[Reply]   [No Email]
Billy NY
06-12-2012 16:09:13
67.248.100.3
 Re: D8 13A PONY TROUBLE in reply to crazytractor, 06-11-2012 20:29:40
Thinking about this, sounds like something is shorting, out of time or retarded, I've never used it, or fooled with it on mine, but there is a manual spark control lever which I assume is for advancing or retarding. For that fuel to detonate like that, has compression, fuel, cylinder loads up with fuel, there is a delay, then ignition or some darned thing, I've never had either of mine backfire, I would be cautious, don't want to break a piston ring or worse.
Where you are you should be able to use 85W-90, but in the winter, or cold climates, the old books said to thin it, but now one would use a different oil.
Just wondering do you have the serviceman's reference book for the tractor, there is information about the magneto and so on, might be helpful, but if not I can refer to ones I have for tractors with the same starting engine.
[Reply]  [No Email]
Crazytractor
06-12-2012 16:17:59
67.10.84.248
 Re: D8 13A PONY TROUBLE in reply to Billy NY, 06-12-2012 16:09:13
I have several service books but not sure if it has all info. My concern is. If it start quick and ran great for a while Why would it be out of time? It only started backfiring after a short while of running, And the it started the backfires. Can low or empty fuel cause this too?
[Reply]  [No Email]
Billy NY
06-13-2012 06:52:23
67.248.100.3
 Re: D8 13A PONY TROUBLE in reply to Crazytractor, 06-12-2012 16:17:59
Low fuel or clogged sediment bowl, carb screen, would not run or shut off. I would think something is going on in the magneto or cap like was mentioned given it was running well prior to. The first time I really fooled with one of these starting engines, I had magneto problems, one needed to be rebuilt, I found another laying about in a shed where leftover parts from another D7 starting engine, might have been a bosch, finally had the timing right and a hot magneto working correctly, fired right up, but was burning oil/smoking excessively, fouling plugs, but was running without skipping or backfiring.
I was reading in an old D7 7M book, says the crank needs to be 25 deg past TDC and is the correct firing point, thats in the servicemans reference book for the starting engine, and about the same as I described in the last post, but I would check the mag, cap and so on, could be a simple fix.
[Reply]  [No Email]
dpendzic
06-13-2012 06:20:07
24.191.49.134
I would check the mag cap very closely---as it heats up the cap will expand some and may have fine cracks that open up and allow a misfire.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
