Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: Swapping excavator engines
[Return to Forum]
Roy Suomi
05-23-2012 18:37:56
76.190.200.252
Never again....Swapped out a Yanmar NTE-88 that was mistreated by a contractor for a Kubota 1903 ..Had to change/fabricate everything to make it work....Motor mounts , radiator, throttle bellcrank as the throttle worked the wrong way, change pump mounting bolt holes by 7 degrees, manual gauges , shut-off cable , oil cooler mounting , exhaust, air cleaner.Made an adapter to replace oil filter with a machined roundstock , drilled channeled and remote filter mount and hydraulic hoses....Kinda like building a hotrod.... many hours later finally done..Works well..Reason for swap as opposed to rebuild ?? Parts list was 3800.00 without doing the head and injector pump, starter.. Kubota was in an unused boring machine with only 40 hours on it....
[Reply]   [No Email]
RGMartin
05-30-2012 04:41:46
173.189.142.201
 Re: Swapping excavator engines in reply to BCnT, 05-23-2012 18:37:56
Weird, I ordered tractor parts from Summit yesterday too.
My wife thought I was up to no good when she saw the invoice on the kitchen table.
[Reply]  [No Email]
Roy Suomi
05-30-2012 06:36:32
76.190.200.252
 Re: Swapping excavator engines in reply to RGMartin, 05-30-2012 04:41:46
My wife thinks I'm up to no good all the time...
[Reply]  [No Email]
jm.
05-28-2012 09:21:51
99.196.0.57
 Re: Swapping excavator engines in reply to Roy Suomi, 05-23-2012 18:37:56
Roy I am 69 years old and have spent the last 40 + years sellin,servicing & repairing heavy equipment. Have seen ever kind of engine swap from a Mack truck engine in a td 20 ih dozer to smaller swaps. In almost every case the end results did not justify the effort. Firt you have to get the motor hooked up and mounted. Then fuel in, air in, exaust out, and cooling water. Then the throttle controls will always be off side.. Just a lot of work. I have an ih scout pickup that I am thinking of putting a KUBOTA disel in and I know I am in for a job but got plenty of time..
[Reply]  [No Email]
Roy Suomi
05-29-2012 03:49:56
76.190.200.252
 Re: Swapping excavator engines in reply to jm., 05-28-2012 09:21:51
I've got everything done with the exception of engine cooling..I found that the electric fan was a puller not a pusher, and a little undersized for application..If the waterpump weren't off-set , I could have used a conventional driven fan on it.. Everything else worked out t*ts..I couldn't believe that I got all that bent tin put back on.. It's a mess..
[Reply]  [No Email]
Roy Suomi
05-29-2012 18:01:00
76.190.200.252
 Re: Swapping excavator engines in reply to Roy Suomi, 05-29-2012 03:49:56
I contacted Summit Racing in NE Ohio today and ordered a Mr. Gasket #1987 fan from their online catalog.. 1500 cfm should do the trick..Alter the fan mount bracket , wire it up and test it..I've got 2 stumps to test it out on..
[Reply]  [No Email]
Ed pap
05-23-2012 19:28:02
184.12.74.217
I just quoted a rebuild on a NTE 88 Yanmar. I felt bad for the guy it was a low hour machine, he ripped the coolant drain hose off under the machine with something and cooked the engine. the parts were crazy and you can"t cross it to anything else. they have those engines shoe horned so tight in those machines i can"t imagine what you went thru to get a Kubota in there.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
