Anonymous-0
working on a 1952 TD-9 crawler with an IH diesel pump. The unit had sat for many years and all the fuel had drained from the system. When started on gas and switched over to diesel it would only idle. Took the pump off and sent it to someone to look at and said the governor was stuck and they got that going and sent it back. After replacing it it now will not run on diesel at all. I think there is still something going on with the pump because I cannot seem to get all the air out of the system. I get fuel at the injector bleeders that seems to be squirting properly but when I close the bleeder it will not run. when I crack the bleeder again there is no fuel there for a few seconds like it is leaking back to the pump or something. Also, when it is running on gas it wants to push some diesel fuel out of the filler cap on the pump where you add oik to the pump. Anyone have any ideas what I should try???
