Anonymous-0
I have a JCB 1400B extenda hoe with a 4.236 Perkins and shuttle reverser trans. machine # 317927/7. Two questions; first I get amomentary buzz when I shift the machine into reverse,the filter clean, fluid changed and full no apparent slipping or trans problems, any ideas about the buzz? Second, just lately the clutch stopped disengaging can"t shift between gears on the fly and macine will continue to go forward or reverse with the clutch in. the linkage is good the rod moves in and out of the trans ok, any ideas? I have a shop manual, but no gauges to check trans, I"m handy with wrenches and can fix about anything, if anyone has a diagnosis I"d appreciate it moneys tight so if I can fix it myself I will. Thanks in advance for any help.
