John Deere 350
Anonymous-0
I have a John Deere 350 crawler loader. I'm looking for a few counterweights for my machine. I currently haven't found any, but when I do, I'm not sure how much to spend on them. Does anyone know how much 1 counterweight would sell for and how much each weighs? Thanks
350 loader requires at least 800 lbs. in the back if there no rear attachments like a hoe or ripper.
OEM 350 weight set was- four weights and two brackets to hold them. Each weight is 200 lbs. A used parts yard is likely to charge $1 per pound plus another hundred for the two brackets.
Original set had three # 8255CU weights and one U20033 weight at the bottom.
350C loader uses the big single T33431
350C loader used one big weight instead of a stack.
There are also sprocket weights.
