Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: Case 9030 B
NCWayne
05-01-2012 12:07:30
Hadn't thought of that one even though I ran into one about two weeks ago that had a similar problem. In that case there was a broken ring terminal where the safety shutdown circuit wiring connected to the oil pressure switch. Terminal was broke and had almost worked it's way out from under the screw to a point that there was just the tip of one end still making connection. It was passing just enough power to keep the solenoid open enough for the engine to run at an idle but bog under a load. Put a new terminal on and tightened it down and the engine went back to running normally.
BCnT
05-01-2012 23:44:37
 Re: Case 9030 B in reply to NCWayne, 05-01-2012 12:07:30
right after i got my 350B i was dozing a fenceline on ranch and dozer just quit...checked everything fuel related and finally realized battery cable had jumped off batt post...had me scratchin my head fer awhile.
