plugs for D4
wilson ind
Have cat Basicly D4 is loader 7U just harder to get to pony motor for work!!! What brand and heat range spark plug do most find to start best?? Just bought tractor. Takes act of congress to get to carb!! does carb have inlet fuel screen?? just not getting enough gas. Thinking of just sea foam. Have heard must use fresh gasoline?? What about getting non ethenol av-fuel of 100 octain?? Whats your opinion??
Champion plugs are not well thought of. It is real common for carb to get plugged up, dependent on filter bowl to clean gas. I like to put a tube in filter inlet with fuel screen so sediment cant get in carb. Not much fall from tank to carb. Usually you can take top off carb in place to clean.
Autolite 386 or a 387 if a hotter plug is needed.
Also the NGK A6 works well.
Avoid Champions
Needs to be a non-resister type plug and use with solid wire core ignition wires.
the NGK A6 plugs are too large to fit in my D2 pony
I am told i have the newer heads which has a smaller plug in the middle rather than the older heads with the plug at the top. What would be the equivalent NGK plug??
Thanks
