Yesterday's Tractor Co. Tractor Parts for All Brands
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: Re: By the way
[Show Entire Topic]  [Return to Forum]
chrisBarwick
04-24-2012 19:39:46
76.6.113.145
1. would that go before the loader valve? That hose is very big and has a fitting on one end that i dont think i can replace and some knuckle head saughtered the other end to stop it leaking. so im trying not to disturb it for now.
2. what if i removed the relief valve and pluged it on the loader? would it then work off the relief valve on the backhoe valve. Would this be combining 3 spools to 6 more waking it work like one 9 spool valve.
3. is there any other option i would love to make this work? thanks again!!
4. Also the plugs i mentioned on the loader valve you can blow air in one and it comes out all 3 even the dump. so i guess no matter wich one i hook to im still hooking to the dump. RIGHT??
[Reply]   [No Email]
Bob/Ont
04-25-2012 13:05:42
70.26.61.215
Chris, check your valve for markings JM mentioned. Don't plug any relief valves.
With open center valves you need to close the open center path to harness the hyd power.
The open center path goes to the return after the last spool in the valve bank.
To use power beyond the center flow needs to be seperated from the return untill it goes through the remote valve and then the remote valve's return also sent back to return. This gets a bit trickey to advise upon here not knowing your valve because you want to keep the flow to the remote valve seperated from the main valve's return to prevent pressure backing up to places in the main valve it shouldn't go. The only power beyong I have ever set up required a plug be installed inside the valve under the P B fitting and the remote valve return flow came back to another fitting in the main valves return. This is the best I can do without seeing your valve.
Later Bob
  [Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
