| Crawlers, Dozers, Loaders & Backhoes Discussion Forum |
Topic: Re: By the way
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| chrisBarwick
04-24-2012 17:03:41
76.6.113.145
It is a crawler t-340 international. i connected the pressure hose to the loader valve. and continued the loop through the backhoe valve back to the transmission/resevior. my assumption was the loader valve had a relief valve? i also plugged the dump side of the loader valve becuase the first time i hooked it up it would only work when i worked the loader controls.-when it went back to nuetral i had no pressure at the backhoe. Hope that makes sense! HOW DO I KNOW IF ITS POWER BEYOND? Can you send me pics or links to the parts your talking about? I realy want to figure this thing out, thanks alot for your reply! |
[Reply] [No Email] | |
| jm.
04-24-2012 19:16:36
75.105.64.53
Re: By the way in reply to chrisBarwick, 04-24-2012 17:03:41
| Chris common open center POWER BEYOND valves have three lines BESIDE THE WORK PORTS.. You will have one marked in, one marked out, and one marked PB or power beyond.. now here is the rub most people get the out and PB mixed up. Out is only a dump back to low presure or tank side. The pb is what will carry the power on to the backhoe valve, IN PORT.. You can buy a seperate relief valve if you need. |
| chrisBarwick
04-24-2012 19:39:46
76.6.113.145
Re: By the way in reply to jm., 04-24-2012 19:16:36
| | 1. would that go before the loader valve? That hose is very big and has a fitting on one end that i dont think i can replace and some knuckle head saughtered the other end to stop it leaking. so im trying not to disturb it for now. 2. what if i removed the relief valve and pluged it on the loader? would it then work off the relief valve on the backhoe valve. Would this be combining 3 spools to 6 more waking it work like one 9 spool valve. 3. is there any other option i would love to make this work? thanks again!! 4. Also the plugs i mentioned on the loader valve you can blow air in one and it comes out all 3 even the dump. so i guess no matter wich one i hook to im still hooking to the dump. RIGHT?? |
| Bob/Ont
04-25-2012 13:05:42
70.26.61.215
Re: By the way in reply to chrisBarwick, 04-24-2012 19:39:46
| Chris, check your valve for markings JM mentioned. Don't plug any relief valves. With open center valves you need to close the open center path to harness the hyd power. The open center path goes to the return after the last spool in the valve bank. To use power beyond the center flow needs to be seperated from the return untill it goes through the remote valve and then the remote valve's return also sent back to return. This gets a bit trickey to advise upon here not knowing your valve because you want to keep the flow to the remote valve seperated from the main valve's return to prevent pressure backing up to places in the main valve it shouldn't go. The only power beyong I have ever set up required a plug be installed inside the valve under the P B fitting and the remote valve return flow came back to another fitting in the main valves return. This is the best I can do without seeing your valve. Later Bob |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
