TractorLinks.com
Re: Streering clutch
dpendzic
04-22-2012 17:00:28
sounds like the left steering clutches are slipping. Were the right steering clutches very worn when you replaced them last year?
are your brake linkages adjusted up properly?
Darrel Christensen
04-23-2012 19:11:31
 Re: Streering clutch in reply to dpendzic, 04-22-2012 17:00:28
According to the book everything looked real close to me
dpendzic
04-27-2012 13:55:33
 Re: Streering clutch in reply to Darrel Christensen, 04-23-2012 19:11:31
try running the machine forward with both levers pulled back just enough to release the clutches but not enough to apply the brakes--you will probably have to remove the seat to observe the linkages.if the machine travels to the left the right clutch may not be releasing--the machine should not move.
dpendzic
04-27-2012 20:48:14
 Re: Streering clutch in reply to dpendzic, 04-27-2012 13:55:33
yes-probably both clutches are somewhat dragging--
perhaps you should adjust up the clutch linkages so you get more of a release before the brake linkage starts to activate and see what that does.
Darrel Christensen
04-27-2012 18:14:49
Hi dpenzic, Have tried what you suggested and the tractor never stopes moving forward until the brakes on both sides stop it. It does not turn right or left before this happens. Does this mean the both clutches are not releasing?
