Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Streering clutch
Darrel Christensen
04-22-2012 10:01:29
I have an International 500C crawler tractor that is hard to turn right. Last year It would not turn left and wound up changing the right streeing clutch. Now it turns left fine but will not turn right very good. I have to put in 1st gear and bring the rpms up to get to turn to the right. I have checked and rechecked the adjustments and ajusted them as close as I can. Can any body tell me what to do the solve the issue, Thanks Darrel
Harry in Ky
04-24-2012 06:35:01
 Re: Streering clutch in reply to Darrel Christensen, 04-22-2012 10:01:29
If it takes extra effort to turn right, it sounds to me like the right clutch is only partially releasing, and some discs are still engaged. When the clutch was out last, was it disassembled and repaired or just swapped out with another unit? I suspect if you have a release mechanism issue there would be something different in how the lever travel feels compared to how it was before this started. Is it a wet clutch with hydraulic steering?
Darrel Christensen
04-24-2012 15:56:26
 Re: Streering clutch in reply to Harry in Ky, 04-24-2012 06:35:01
The whole clutch was replaced last fall and they are dry clutch. Your right about one thing. I don't think the clutch is releasing like it should. However all the adjustments are as close to the book as I could get them.
Darrel Christensen
04-24-2012 15:49:17
The last time the clutch was last fall whin I replaced the pressure plate and all the disc (steel and fiber).
dpendzic
04-24-2012 07:33:18
500C tractors have dry clutches
dpendzic
04-22-2012 17:00:28
sounds like the left steering clutches are slipping. Were the right steering clutches very worn when you replaced them last year?
are your brake linkages adjusted up properly?
Darrel Christensen
04-23-2012 19:11:31
 Re: Streering clutch in reply to dpendzic, 04-22-2012 17:00:28
According to the book everything looked real close to me
dpendzic
04-27-2012 13:55:33
 Re: Streering clutch in reply to Darrel Christensen, 04-23-2012 19:11:31
try running the machine forward with both levers pulled back just enough to release the clutches but not enough to apply the brakes--you will probably have to remove the seat to observe the linkages.if the machine travels to the left the right clutch may not be releasing--the machine should not move.
dpendzic
04-27-2012 20:48:14
 Re: Streering clutch in reply to dpendzic, 04-27-2012 13:55:33
yes-probably both clutches are somewhat dragging--
perhaps you should adjust up the clutch linkages so you get more of a release before the brake linkage starts to activate and see what that does.
Darrel Christensen
04-27-2012 18:14:49
Hi dpenzic, Have tried what you suggested and the tractor never stopes moving forward until the brakes on both sides stop it. It does not turn right or left before this happens. Does this mean the both clutches are not releasing?
