Yesterday's Tractor Co.
Shop Now View Cart
Re: D2 CAT
04-20-2012 19:16:46
Mine runs great once you get it runing, but you have to either it every cold start. No blowby and doesn't use any oil. Thanks Doug
04-20-2012 20:19:55
 Re: D2 CAT in reply to DGK, 04-20-2012 19:16:46
how long are you turning the diesel over under compression to warm up the chambers and intake manifold?
04-21-2012 15:55:15
 Re: D2 CAT in reply to dpendzic, 04-20-2012 20:19:55
Probably 2 min. in 60 degree weather. ALSO do u open throtke then or probbly better to wait until cyls are warmed up mpre. Thanks Doug
04-21-2012 19:18:26
 Re: D2 CAT in reply to DGK, 04-21-2012 15:55:15
Every Cat seems to start differently. I know all mine do. I have one 7U that was all rebuilt in good shape. I have to turn it over until I can feel the head warm up before it will even cough and then it labors to start. I just wait until the oil pressure comes up and give it sniff of starting fluid. I have another one that has a weak cylinder and burns a gallon of oil per hour. As soon as the oil pressure comes up I shove in the compression release it is off and running.
I had an old 5U back when parts were affordable from Cat. I replaced every wearing part in the transfer pump and never got it to start without a sniff.
04-21-2012 18:11:44
at 60 degrees I turn mine over about that same time, and i do give it a quick shot of either to fire it off.Colder temps you need to run the pony longer or supply external heat to the intake manifold.
every fuel pressure gage reads differently, the calibration goes off, and many machines have all different model gages, the one I have now i got off ebay and its a SW gage.
