Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Case 1450 crawler loader
JD in SC
04-19-2012 14:40:11
I"m rebuilding the engine in my Case 1450 loader (504BDT Case engine). All clearances meet spec except the rod side clearance. The spec is 0.007" to 0.016". My rod clearances range from 0.020" to 0.050". Since the rod journal spec is 1.9775" to 2.0025" (0.025" range), it seems to me that the rod side clearance spec is bunk. If I had rods designed at the narrow clearance and the rod journal is wide, theoretically I could have 0.007 + 0.025 = 0.032" clearance. Am I seeing this right? Any thoughts?
Dave Panning
04-21-2012 06:28:48
 Re: Case 1450 crawler loader in reply to JD in SC, 04-19-2012 14:40:11
For some reason some crankshafts seem to wear the "cheeks" of the rod journals & 504 Case seems to be one of them. We have had to have some of these 504 crankshaft welded up & reground to get back into specs. Yours doesn't seem too bad. I've seen worse. I'm not sure how much you could get by with?
Copyright © 1997-2015 Yesterday's Tractor Co.
