| Crawlers, Dozers, Loaders & Backhoes Discussion Forum |
Topic: Re: Rough idle after roosa master DB reseal, case 207D LJD??
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| Dieseltech
04-14-2012 18:41:53
199.16.223.2
Was new retainer timing line marked at correct location on degree tool per spec sheet, if off 1 degree will be 2 at crankshaft. If not sure can try shifting timing to see if it likes either advanced or retarded change. Was housing return valve either cleaned or replaced, if old one is on with ball knocked out advance will start to move earlier with no housing pressure. |
[Reply] [No Email] | |
| mikefromcny
04-14-2012 20:47:27
24.58.230.170
Re: Rough idle after roosa master DB reseal, case 207D LJD?? in reply to Dieseltech, 04-14-2012 18:41:53
| | I did mark new retainer in reference to the old one. Would it still run if 180 degrees off? I doubt it could be since it runs as good as it does. I still have a "punched out" check valve on the housing cover. I thought I could clean out my old one as I punched out a check valve from a spare pump. I will buy a new check valve and try that. Thanks! |
| LJD
04-15-2012 05:54:16
75.213.173.126
Re: Rough idle after roosa master DB reseal, case 207D LJD?? in reply to mikefromcny, 04-14-2012 20:47:27
| It won't run 180 degrees off. The fitting with the ball and spring is the housing-pressure-regulator-valve. Not just a fuel check valve. New one costs $7. It maintains internal housing pressure at around 5-6 PSI. Running without it would make the auto timing advance cut in a little earlier. I doubt it's your problem. But . . have you checked the timing advance? To do so, you need a $10 plastic timing window. Maybe you can borrow from a Deere mechanic? |
| mikefromcny
04-17-2012 17:40:47
74.78.221.211
Re: Rough idle after roosa master DB reseal, case 207D LJD?? in reply to LJD, 04-15-2012 05:54:16
| Dont own the timing window tool, dont know anyone that does either.
LJD, Do you have a list of "must haves" for resealing the roosa masters? I have another I'll eventually have to do on my JD 350 and just looked at a real sorry looking 3010. A friends father has a stalling waukesha in a 1655 that might become my problem.
Does US diesel sell the specialty tools? if so I need to buy enough to meet the $50 minimum.
I could use the timing window tool, umbrella shaft seal compressor, the "bristol wrench" Any others I should have? Parts numbers would be be real helpful too. Thanks. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
