Yesterday's Tractor Co.
Shop Now View Cart
Re: case 580k
04-04-2012 20:07:24
i turnes engine over by hand and pushed button at same time never would lock in so i removed #1 valve cover till both valves were closed then i removed pump i alkso removed #4 valve cover one closed one open. how bad off will i be
Dave in Tx
04-18-2012 18:04:32
 Re: case 580k in reply to peter82, 04-04-2012 20:07:24
Turn the engine until the #4 exhaust valve just closes and the intake just starts to open. Right where the x closes and intakes starts, just starts to open is very close to tdc.
04-04-2012 22:48:17
How far off you might be is hard to say, but like the old saying, "A miss is as good as a mile". In other words when you get the pump back from the shop they should have it timed exactly but, obviously, the engine will not be timed exactly. That being the case, wether your 5 degrees off, or 15 degrees off, or 180 degrees off, the pump will be out of time with the rest of the engine and it will not run right, or possibly at all.
My suggestion would be to pull the plunger assembly and get a new one if the small part on the end is broken off. Too, I have seen them be just be stuck enough that they will not push out and engage the timing hole without literally driving it out with a hammer. In that case, simply pull the assembly and free up the one that's there so it will push in and engage the timing hole like it's supposed to do.
Based on what your saying you did, you ought to be close, so once you have the timing pin situated rock the engine back and forth while pushing in on the plunger til it engages with the hole. Unfortunately that is the only way your going to have any guarantees as to wether the engine will be in time and run when your done.
