Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: Re: case 580k
[Show Entire Topic]  [Return to Forum]
NCWayne
04-03-2012 23:48:01
69.40.232.132
Not sure exactly which pump yours has, but a 4BT Cummins with an inline injetion pump has a plunger located directly below the front of the pump where it mounts to the engine housing. Turn the engine over slowly by hand while pushing in on the plunger. You will eventually feel it drop into a hole on the back of one of the timing gears. Once it drops in place everything is then in time. Now looking at the front left side of the pump (viewed from the rear), there should be a bolt tightened down on a little tab. Sometimes the tab is connected with a wire, somethings not. Anyway back off the bolt just enough to remove the tab, then tighten the bolt back down. With the tab removed the bolt is allowed to go in far enough to lock the internals in the injection pump in time...so save the tab, you'll need it when you go back together with it. Once everything is locked down I'd suggest that you pull the plunger backout of the hole it lines up with. I say this because if, while removing the pump, something gets turned even a little bit it will break the tab off.... BTDT.... Just make sure you put it back in place before you start reassembly to insure everything is still in time....From there unscrew the plug on the front cover, and go from there to get the injection pump off of the engine.
Good luck and I hope this helps.
[Reply]   [No Email]
peter82
04-04-2012 20:07:24
204.116.212.19
Re: case 580k in reply to NCWayne, 04-03-2012 23:48:01
i turnes engine over by hand and pushed button at same time never would lock in so i removed #1 valve cover till both valves were closed then i removed pump i alkso removed #4 valve cover one closed one open. how bad off will i be
  [Reply]  [No Email]
Dave in Tx
04-18-2012 18:04:32
166.147.72.21
Re: case 580k in reply to peter82, 04-04-2012 20:07:24
Turn the engine until the #4 exhaust valve just closes and the intake just starts to open. Right where the x closes and intakes starts, just starts to open is very close to tdc.
  [Reply]  [No Email]
NCWayne
04-04-2012 22:48:17
69.40.232.132
How far off you might be is hard to say, but like the old saying, "A miss is as good as a mile". In other words when you get the pump back from the shop they should have it timed exactly but, obviously, the engine will not be timed exactly. That being the case, wether your 5 degrees off, or 15 degrees off, or 180 degrees off, the pump will be out of time with the rest of the engine and it will not run right, or possibly at all.
My suggestion would be to pull the plunger assembly and get a new one if the small part on the end is broken off. Too, I have seen them be just be stuck enough that they will not push out and engage the timing hole without literally driving it out with a hammer. In that case, simply pull the assembly and free up the one that's there so it will push in and engage the timing hole like it's supposed to do.
Based on what your saying you did, you ought to be close, so once you have the timing pin situated rock the engine back and forth while pushing in on the plunger til it engages with the hole. Unfortunately that is the only way your going to have any guarantees as to wether the engine will be in time and run when your done.
  [Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
