JD 450 Crawler/ Roosa Master injection pump
BBROWN33
New User
I've got an older JD 450 Dozer with a CBC 431---3AL /Roosa Master injection pump. It had started to leak behind the throttle linkage housing. went to tighten it up and I broke it off. I have called around to several places to try and find a pump but nobody seems to know where to find one. Any ideas.
Go to a diesel injection repair shop,they'll have the pieces you need to repair your pump.
If you can't find what you need, i got a pump here with a broke drive shaft.
I you can tell me exactly what you broke i might have it.
I have several Roosa master pumps off of JD's,
email me a photo of what you broke ,I most
likely have several as I fix pumps part time.
There is very little in or on a Roosa master that
can't be repaired.
george
Check out this link for US Diesel parts.
http://www.usdiesel.com/dieselinjection.htm
They will sell parts for that inctor pump. Be sure to get the full details off of the name plate on the pump casing.
HTH
J.
i am looking for used pump,trying to help a guy that had a stroke get tractor running to sell for bills. i have a new shaft on the shelf. let me know if you could sell one please
(quoted from post at 20:01:58 04/29/11)
can't be repaired.
george
George, I have a Roosa Master CBC-431 3AL injection pump on a JD400 wheel loader. the rack portion on the rack and pinion accelerator lever is stripped, would you by any chance have parts for such an accelerator lever?
I would send you a photo, but I just registered here and I don't know how to attach a photo.
Hank
