My 2002 model New Holland LS 150 skid steer has been intermittently indicating low hydraulic charge pressure and shutting down the engine. I was able to restart it and operate it up till today. It has been setting for a few weeks but now will not continue running and indicates the hydraulic charge pressure is low.
I heard these sometimes have a defective hydraulic charge sensor and also that maybe a filter change will fix it. It only has 300 hours on it and everything else works fine. I plan to remove the sensor if I can find it!
Anyone with experience with this problem with some advice?
Also the battery is the original and I suspect it is on borrowed time. Any suggestions on a replacement? I suspect the NH batteries are very expensive but the terminals connect to special studs instead of normal posts.
