Anonymous-0
I need to make an attachment or maybe 2 but would like to try and make only 1 that could serve multiple purposes. I could make a root rake with closer spaced tines but don't know if it would work very good for scarifying hard packed clay. The other option is to make a rear scarifier and use it for pulling up roots after I clear tree's. A root rake would be made to fit on the front 4 in 1 bucket and the scarifier would mount to the quick attach backhoe mounts. The machine is a Cat 931B loader with 1 yd. bucket and weighs about 17,500 lbs. I need something simple to groom a MX track when it gets packed really hard. I only need to go 6 to 8 inches deep and the box scraper won't do it and the tractor isn't heavy enough. I figure on the Cat, I'm not as likely to break something. Any help is appreciated. Dave
