Oliver OC 46 Aircleaner
mikenofx2000
New User
Im starting to go through my oliver to find out what parts i need.
I am missing the air cleaner set up from the carb all the way up through the hood i dont have mounting brackets or anything. Ive searched online for one without much luck, Can i get an aircleaner off of a more popular more common tractor or is this cleaner model specific?
Thanks
Mike
Any air cleaner will work. Remember the goal is to get clean air to the motor. Try and find a newer air cleaner assembly that looks close to something that will fit and then adapt it using whatever you can. Use rubber boots or old hose and clamps to attach things....whatever works until you are getting clean air to the motor. The engine will only suck as much air as it needs so almost any intake will work (stay away from oil bath intakes, substitute with cyclone style).
Heres a pic of ours,if you can call Zimmermans,I'm sure he has all of it.Ours is a OC46.Hope this helps
Victor
Air filters have to be sized for the air intake(cfm's) of the engine. What's wrong with a good oil bath air cleaner? They were once very popular with thousands still in use on all kinds of older equipment. Dave
