LOU from WI
We were looking at some new Berco dozer pads for our OC46,as the old ones are worn, bent and a couple are loose(rivets). So found some the right width & length,but with different mounting holes. Has anyone done any metal work with Boron Steel Shoes? IE welding up the mounting holes,and redrilling new. I looked at some Cobalt,tungsten,and even Diamond coated drill bits.So far it's a guess,lubricating the bit is a must. I know it's possible,but a plasma cutter, or acetelyne torch is out of the question cause I dont want to take the temper out of the steel,plus getting the holes the right diameter by hand is a little hard.Re welding the holes will have to be done in slow steps,a little here and there,let it cool and reweld over.Granted buying used will work, but in our case most of them are either worn pads and or pins and bushings,so this way we can have new pads with no worry about wearing them down. Was just curious if anyone has tried this and had a easy way to do it (drilling). I know making a pattern from the old shoe and transfering it onto the new for bolt location. Thanks for any pertinate info.Reguards,
Victor & LOU
Victor & LOU
