580 B CK Differential Brake Questions
okney1lz
New User
Hello everyone! I'm a new user who stumbled across the forum a little while ago and thought I'd see if some of you guys could shed any light on a few questions I've had recently.
My biggest Christmas gift this year was a 1972 580 B CK Backhoe. Long story short, it was given to me for nothing. It has the shuttle trans, Model 35 Hoe, Diff lock and only 2100 hrs on the clock. The machine has basically just sat unused for most of its life. It's rough but in decent shape in my opinion. I'm pretty familiar with the machine as I rebuilt all of the hydraulic cylinders about ten years ago for the previous owner, a long time friend of my family.
I had messed around with the brakes back then and made them "semi-functional" if you could call it that. When I had disassembled them way back then, to reline the brake surfaces, I noticed that the housings (#25 on Case's website) were gouged pretty badly where the drum (#14) had chewed into them. So I replaced just the linings and reassembled, fingers crossed. Performance was lacking to say the least.
Anyway, now that the machine is mine I’ve realized that brakes and stopping aren’t as highly overrated as I had once thought. Go figure! So I am about to get back into them and see if I can get them serviceable. The pedal went to the floor, so yesterday I adjusted and greased the linkage to no avail. The brakes attempt to stop after an enormous amount of pressure has been applied but feel as though you’re stepping on a brick, as though maybe the drums are never moving towards the housing. Easy fix, not the solution, check!
So here are some of my actual questions:
Can the housing be repaired? Welded and machined? Case wants an arm & leg for them.
Can the drums be repaired? Or is all of this dealer stuff?
How much wear is too much on the actual brake disc where the balls ride?
Could the discs and drums be frozen to the shaft?
In general how do you feel I should proceed? Which parts should I replace at a minimum?
Also, I remember it being unusually tight between the right housing and the backhoe mounting frame. Are there any tricks to make that side easier?
Sorry for the insanely long post! Thanks in advance for any and all input, insight, or advice anyone can offer.
Lawrence
Not trying to be a smart azz, but if you can get brakes on a 580 B and keep brakes on it for any length of time you are genius.I have worked on so many of these in the last 30 years I have lost count.First of all, in my opinion they were undersized for the machine. They are a supposed to be dry brakes, but I don't think I ever tore one down that didn't have oil on them. Seals just not heavy enough.You can replace every thing in there new and do it buy the book and then baby the machine around and keep good brakes on it for a while,but if you run it hard, stop it fast, the discs will glaze up ,the seals will leak and no brakes again. Good Luck.
