The original hydraulic hoses to and from the 33 hoe control valve assembly have been replaced with aftermarket ones that I need to replace. One is a 3/4 inch and the other is a 1 inch. I can not determine what is supposed to be used. Case says NLA so I have to get them made and the local dealer makes up to 3/4 inch but is not able to find a reference for the correct size. Since one was a 3/4 and the hoe worked, I am guessing I could get those and be okay......but I am challenged when it comes to hydraulics..... Flow restriction supply and return size for that valve is info I have not seen yet.?
Does ANY restriction in the system of 3/4 inch mean that hoses can be that size and not affect use? The flow passes through at least one 3/4 fitting at the 4 way headed back to the hoe.... Does anyone know what was/is correct for proper flow? Those local made 3/4 inch ones would be handy but I will get bigger if the system requires.....
Thanks
Thanks
