My 69 Case 580 with a 33 backhoe went Crazy Ivan on me.... the right outrigger control became very hard to move and sticks badly even if the tractor is off.
In addition the gas motor is stalling unless I operate either the loader or hoe.... then it roars off. As soon as I stop using hydraulics the engine bogs badly and dies out. Seems to be under load like the sytem is stuck in a loaded mode. That outrigger control works when running but is not right as it is sticking and very hard to use.
The filter gauge went from good to bad as soon as this happened. Of course I am going to change the filter but I am guessing the clogging or restriction is in the system due to the outrigger control? What do you think... Does this sound like the hoe has to come off to work on the system? Thanks Ralph
