Sometimes it will run for 5 minutes sometimes for an hour. Then it will not start or will only just catch for a few seconds. Most of the time it runs arounds 5 minutes or less. I thought it was air in the fuel system. I have replaced all of the filters cleaned out the tank and I had good flow to the filters. I have bleed it multiple times and this doesn't seem to help. Does the priming pump go bad and possibly cause air leaks?
I have tried everything else I could think of. When it runs I have no problems at all with any of the systems.
Thanks
Thanks
