I have an early '70's JD 410 backhoe I purchased almost 5 years ago. I use it around the farm and never in a hurry.
I didn't know what to look for before purchase. So the front bucket being really, really slow after warm up went unnoticed. As did the excessive bleed down and lack of power in the rest of the hydraulic systems.
I tested the pressures in the system a couple of years ago. 1500 lbs. cold, 1250 warm. System is supposed to be at 2300-2400 lbs. I don't have a flow meter, but was told the pump was replaced about 5 years before I purchased the machine. He gave me a box containing the old pump.
Since every system was bleeding down and I had a ton of oil coming out of the return line with all the valves in neutral, I guessed it was in the valves. I purchased rebuild kits from John Deere.
Today I pulled the valves. Looking at the spool through the port, I see that "97" has been inscribed on all the spools.
Questions: Does that mean that someone rebuilt the valves in 1997? I wouldn't think they'd need it now. If that is the case, I'd just replace the "O" rings between the valves and put them back.
If it isn't the valves, does that indicate I have to rebuild all the cylinders? Or could there be some other problem to look at?
Thanks,
Brian
Thanks,
Brian
