1835B injection pump timing
Andy Moss
New User
Anyone know where the timing marks or timing pin is located on a Case 1835B uniloader?
I was able to line up the pump marks and pull the pump, but need to be sure when I reinstall it. I also need the timing specs if it dosent use a pin to time.
There are no marks on the balancer or timing cover.
Thanks,
Andy
not sure if it uses a pin but the marks are on the flywheel. the inspection hole is on the side of engine opposite the pump. I had to do this once on mine and there were so many marks on the flywheel I was never quite sure I got it where it should be, but it runs ok. I dont know the specs. I think you should have set the flywheel first, then removed the pump. These are the same engines used in the older Case backhoes and dozers(188/207 cubic inch) so someone should be along that can be of more help to you.
