I have a '79 JD 410 that was open (tranny cover off) for a couple of years to replace the rear end. Got her back together last year. Running good, until the past week or so. I have changed the hydro oil once since I put new oil and filters in the machine apon putting the machine back together.
Now it seems I am losing power and speed on the hydraulics when the machine gets warm. Almost to the point to where I cannot lift a bucket of dirt when the machine is hot.
I did learn last winter that I had some water in the fluid last winter. I thought I had gotten it all out when I put the new filter and oil in this spring. No luck.
Pressure is fine at 2350 and machine moves fast when cold... just gets worse when warm.
Should I just do the filters and oil again, or should I look elsewhere?
Thanks in advance.
Thanks in advance.
