Anonymous-0
I want to take the backhoe of my Cat so I can haul some clay with loader. I put a block under in so it doesn't go too low to be able to hook the lines together. I've had it off before and it's easier to take off than put back on. The problem I have is that I can usually connect one hyd. coupler and the other one is always a pain to connect, like it still has pressure on it. I have new couplers. Not Cat but good couplers. What is the proper procedure for mounting and dismounting a quick attach hoe on a crawler? I don't have a manual for the hoe but since I think they're all pretty similar(ie./ JD, Cat etc) I was hoping one of you guys on here would no the easiest way to get the hyd. couplers together and/or relief the hyd. pressure. I thought maybe if I loosen the hyd. filler cap to let off the tank pressure would help but I still think there's a simpler way to do it. Any help would be appreciated. Thanks. Dave
