Anonymous-0
The guys that bought my 1987 (last year) JD 355D loader need some help. I'm pretty sure that the reverser was/is leaking into the final drive case. They kept adding oil to the reverser and the level when up in the finals. I've heard that's a common problem. I haven't talked to them in over a year because the one guy backed out of buying my garden tractor after using it for 4 months and even breaking the blade engagement cable so the blades always kept turning. Anyway I talked to him and I said I'd try and get him some info. Apparently the machine stopped moving about a year ago. The reverser used to work good. It shifts gears without grinding but won't move at all now. They were going to pull the engine to try and see what's wrong. Some help from the JD experts would be appreciated as to what to check and how to proceed to find the problem. I don't want to have to tell them it's going to cost thousands to fix or they'll blame me. It did take me a long time to finally get paid for the machine. It runs great and has almost new undercarriage. I say almost new because the bolts came out in the end of the axle on one idler and they kept running it. It wore grooves in the idler blocks. They got that kind of fixed but the axle for the idler was wrecked. I gave them the old idlers to take the best axle out of to reuse. It was a little sloppy but they are pretty cheap. The bolts came out for some reason, the first time, and they caught it right away. I told them to put lock-tite on the new bolts so they wouldn't come loose. They didn't and the bolts came out again. Don't know why they came loose? Now because they don't believe in finding out why they have to keep filling the reverser, the machine won't even move. I said I'd try to get some info for them. I completely rebuilt the finals and put new brake bands in it. I found the duo-cone seals for way cheaper than the JD price. The last time I saw the machine, I think they said it got barbed wire wrapped around the axle. They hardly ever clean the mud and manure off the track frames. This gives you an idea of their maintenance and common sense. Thanks in advance. Dave
