MF 2244 Crawler/Loader
RussUPMI
09-29-2007 17:02:25
I am having trouble finding the tractor serial number. My operator's manual says right side on clutch housing. However, I have a later machine with the hydraulic reverser [no clutch]. Is the number located in a different location or is it that the number plate on my machine is missing? Any help greatly appreciated!
JimInOz
10-01-2007 23:40:04
 Re: MF 2244 Crawler/Loader in reply to RussUPMI, 09-29-2007 17:02:25
Hi Russ,
Maybe you have the later 200 model.I think all 2244 had mechanical shuttle,as did some early 200s.
The 2244s had thinner crowd arms & slightly smaller track gear than the 200s.
My 2244s had Serial# on clutch hsg.
jim
RussUPMI
10-02-2007 06:20:33
 Re: MF 2244 Crawler/Loader in reply to JimInOz, 10-01-2007 23:40:04
Thanks for the info. My machine has 2244 decal on hood and my shop manual states that 2244's had hydraulic reverser after serial# 7022850. I need to find the number plate for this particular tractor. Hopefully, someone out there is reading that has the later model 2244. I e-mailed Big Dean and he suggested posting for Marlowe. I may yet do that.
hectorgemme
09-30-2007 02:32:40
I dismantled a 2244 for parts and the serie number was on frame loader right side.
RussUPMI
10-01-2007 05:22:42
 Re: MF 2244 Crawler/Loader in reply to hectorgemme, 09-30-2007 02:32:40
There is a number plate there for the Drott loader. The tractor number should be on the tractor somewhere, I think. Thanks!
AJK
09-30-2007 01:22:20
They might be referring to the steering clutch housing.
AJ
RussUPMI
10-01-2007 05:28:20
 Re: MF 2244 Crawler/Loader in reply to AJK, 09-30-2007 01:22:20
My outdated operator's manual shows a picture of the number plate between the motor and the fuel tank, right side, just above the clutch housing. My crawler does not even have a flat spot there to attach a plate.
Thanks for the reply.
