International T6 dozer.
Paul Dobbins
04-16-2006 09:44:00
I have recently purchased an International T6 dozer. It jumps out of 1st gear pushing. I was told to bend the gear shift so that it would go in further. Now it will not stay in 1st gear at all and it makes a lot of noise. If anyone can tell me how to fix it or has a manual on the transmission I would appreciate the help. Thanks in advance.
rockspringfarm
04-24-2006 17:20:02
 Re: International T6 dozer. in reply to Paul Dobbins, 04-16-2006 09:44:00
my did the same thing, I took the top cover off with the shift lever and had a machine shop rebuild the rails with some weld and ground it down. a relatively easy fix. worked great after that. mine was a fortys model and the trans. was what we used to call a top loader type.
CH
04-18-2006 03:24:49
I have T6 and TD6s for parts,email for my link
PD Mechanical
04-16-2006 13:07:51
You"ll probably end up having to tear into the transmission. I have manuals and some used parts available if you need them. Contact me directly for more information. sales@pdmechanical.com
R-cubed
04-17-2006 20:13:22
 Re: International T6 dozer. in reply to PD Mechanical, 04-16-2006 13:07:51
First gear is the one where you can get in a hard push and break something. (Finals) Don't use 1st gear. You can get by with second on most tractors by just not taking quite so big a bite. It may run for years without tearing it down just by doing that simple rule. Unless you have fun getting greasy up to your elbows.
