JD350 steering clutch adjustment
Michael Clark
12-27-2004 05:04:17
Can any one give me the procedure on adjusting the steering clutch on the JD350 crawler as I have no manual? Thanks!
jdemaris
12-27-2004 06:31:33
 Re: JD350 steering clutch adjustment in reply to Michael Clark, 12-27-2004 05:04:17
This is, as asked for, a "quick" rundown on adjustment. This is assuming the adjusters
are not rusted fast and the clutches are not swelled or stuck. It's difficult to describe this
without photos to follow, but I'll try. Keep in mind, you want to achieve a situation
where, when the steering lever is pulled back, first there is some free-play (before contact
with the clutch throw-out bearings), then clutch disengagement . . . then just as the clutch
is fully disengaged, the brake starts to grab. You DO NOT want the brake taking hold
while the clutch is still engaged. That being said, pull the little top cover off the clutch
housing you wish to adjust (four bolts). Then, find the initial-adjuster on your brake band
- probably takes a 3/4" inch wrench, look for a nut on a threaded stud attached to one end
of the brake band. It ought to have flats on it so it wants to rest in one of two possible
positions, 180 degrees apart. Turn the nut clockwise until snug (not wrench-tight, just
snug). Then back off one turn. Now, notice how the linkage inside the housing operates
when you pull back a steering lever. Theres a little threaded rod with a small ball joint at
each end. One end is spring loaded and can be popped off for adjustment. When you pull
back on a steering lever, that threaded rod acutates a flag-shaft that in turn, pushes on the
steering clutch throw-out bearing. The action of the said threaded rod also, at a certain
adjustable point, begins to engage the brake. The point of brake engagement is
determined by a bolt locked by a jam nut; 3/8" bolt I believe. So, to put things in proper
sequence, loosen the brake-actuating bolt and back off for now. Then, set the free play in
the steering clutch by popping the threaded rod off and shortening in (by turing in a ball
joint end on the threads). If you get an inch of free-play at the start of travel in the
steering lever, that's fine. Keep in mind there's probably slop in the lever an linkage too;
you must have actual free play in the clutch. You can look down with a flashlight and see
the throw-out bearing and clutch fingers if you're not sure. Note: If you cannot get
free-play because the clutch pressure plate fingers are too high, the clutches are probably
swelled and rusty. It is possible to re-adjust the pressure plate fingers from the outside,
but it's difficult. Assuming you've got the free play, and you'be done the inital adjustment
on the brake band, now you want to pull back the lever until the clutch disengages. At
that point, adjust the brake actuating bolt so it just makes contact when the clutch is
disengaged. This is easier to determine by running the machine. When I worked for John
Deere, I'd put the crawler on a steep hill facing up. Put it in forward and start climbing
the hill, and then pull the levers back until the crawler rolled backwards. If it won't roll
backwards, then the brakes are grabbing too soon. You should have a narrow spot in the
lever travel where the cluthes are disengaged but the brakes are not quite grabbing yet -
that's why the crawler should roll backwards.
Michael Clark
12-27-2004 07:00:00
 Re: JD350 steering clutch adjustment in reply to jdemaris, 12-27-2004 06:31:33
Thanks so much for your time. The clutches were stuck orginally & I had disasembled & cleaned everthing, saw no notable wear. The left side works fine now. The right side steers, but slips when pushing.
MrBill
01-03-2005 11:12:47
 Re: JD350 steering clutch adjustment in reply to Michael Clark, 12-27-2004 07:00:00
Michael,
My 350b left side slips while pushing.
JDEMARIS or to anyone, does that mean the clutch adjustment is too tight and does not totally engage? I had a full load in the bucket and when backing out, would not back straight out but kept turning because the left track was not pulling. I pulled JDEMARIS instructions and tried to follow them. On the left, the ball joint link is adjusted all the way out, no more adjustment. On the right, the 3/4 brake bolt will not turn. The head acts like it is recessed in the lever and will not turn the 180, either direction.
Another problem, the foot brake does not work. The linkage under the floorboards acts like it is not connected to anything at the rear. Where is it supposed to connect? I can udjust the yoke on the linkage all the way either direction and no change. The pedal goes to the floor with no effect.
Thanks for any help, MrBill
Michael Clark
01-06-2005 09:25:38
 Re: JD350 steering clutch adjustment in reply to MrBill, 01-03-2005 11:12:47
After reading the follow up instructions on the adjustment, it makes total sense. Although I don't care much for the design. To start with I poped off the ball joint, backed off the 1/2 headed adjustment bolt then tightened the 3/4 headed bolt snug. Backed it off 1 turn, this should set the initial clearance on the brake band. Then I adjusted the ball joint linkage so it would pop back on. This is what disengages the clutches. Pull the steering lever all the way back to the seat, tighten the 1/2 headed bolt until it pushes the lever about 2 inchs from the seat. This is what applies the brake band. The ball joint linkage is what disengages the clutch so you may have to lengenth it a couple of rounds at a time, trying it out after every adjustment. If you hear a ripping noise or it won't steer keep lengenthing the linkage until it works. This isn't exactly how it was explained to adjust it but it worked for me!
JimInOz
01-03-2005 14:06:31
Hi Mr Bill,I'm in a learning phase with these things too.The JD experts give good advice here.
I'm having slippage problems with L/H clutch too,after having the thing apart already.I think these things are susceptible to condensation,though not sure if it's owner misuse,or inherent design thing.When I took mine apart,it was quite rusty/dirty in the Steering clutch compartment.I was also told yesterday to just replace everything,while you're in there...Pressure Plate & discs.I replaced metal discs & P.Plate springs,but it still slips,so I'll do as suggested now.I'm amazed at the steering dramas that these things have..almost every JD 350 problem on this board involves steering.I quite liked the IH steering system,plus the Mitsubishi are user friendly too.
Good luck.
