brake fluid in a Case 580c?
jeff
09-04-2003 07:45:16
Hydraulic, or actual brake fluid?
Jim B.
09-06-2003 19:33:01
 Re: brake fluid in a Case 580c? in reply to jeff, 09-04-2003 07:45:16
OK straight from the manual- thru a few conversion charts Case Part #'s to Real part #'s--- DOT #3 brake fluid. ONLY in the two masters on the left side thru the oval access plate hole in top of dash.
Jeff
09-06-2003 22:24:55
 Re: Re: brake fluid in a Case 580c? in reply to Jim B., 09-06-2003 19:33:01
Excellent, thx!!!
Brokenwrench
09-06-2003 17:09:58
It should say on the mastercylinder cap. I'm not 100%, but I believe its mineral oil.
JimKS
09-06-2003 15:10:37
Brake fluid if I remember right... but I'd reccomend you call a Case dealer and make 'em look it up- don't pour anything in there until you're sure as mixing oil and brake fluid will ruin every seal in the hydraulic brake system.
so no one knows, eh?
09-05-2003 12:43:16
please?
