Good evening all,
I recently purchased a 4500 Industrial Tractor / Backhoe. I purchased knowing that it has transmission issues, previous owner said that he could use it for about 20 minutes, then it would quit moving. When I went to pick it up, I moved it about 100 feet and then it quit moving. I do have the owners manual on the way, so I at least know where to check fluids and what the correct type is etc. I did loosen the line coming from the top of the transmission that goes to the filter, it was moving fluid when running.
Any other thoughts on things I can try/ look for before tearing into the transmission?
Thanks,
Cordel1
Thanks,
Cordel1
