Like the title says, I have a Cat D6C, Not sure of much else about it other than it has the turboed engine, I believe it is around a 1970 model year. My questions are lube related.
Engine oil capacity
Transmission oil capacity and recommended viscosity It has the 3 forward/3 reverse shuttle shift.
Final drive fluid capacity and recommended Viscosity
Serial# on the tag under the instrument panel RS is 76A5579 if that helps
Thanks for any help you can offer with my needs!
My Cat parts dealer wasn't a lot of help other than filter numbers.
Engine oil capacity
