Hi all,
This is my first post to start learning about the D2 Cat. I'm looking at one to buy, it has a serial number 5U-15692. I can't seem to locate anything online that helps me know what year this is.
I'm guessing '1953, but it could be newer. The 5U is the wide track with 16" tracks, 5-rollers, solid front idler, looks to have a #41 hydraulic pump behind the brush guard, PTO in the rear over the draw bar, not sure what kind of dozer blade this is? Also-I'm unsure about the clutch. Is it a dry clutch or wet clutch? Is there a serial number cutoff to determine?
I assume it is the 311 diesel engine, with gas pony motor. Not sure if its electric or not.
Any help is much appreciated, thanks!
This post was edited by Hiranger on 04/12/2022 at 02:29 pm.
