Hey all,
I have a Cat 96J that one day just decided it didn't want to start. I narrowed it down to an issue with fuel pouring out of a
nozzle (circled in picture) under the fuel pump injector. I took apart the injector to look at the washers and they were in rough
shape, went to replace the washers and a whole new injector was cheaper so I ended up just getting a new injector. Ended up not
fixing the issue. I had a guy from Cat out who said that it might be the seals in the ?manifold? (arrow pointed to it in pic) next to the injector. Now he was
an old timer but admitted to not having worked on a 96j since the 70s. His fix would be quite a bit of labor so I just wanted to
see if anyone had any ideas what could be causing this before I tore the whole thing out. Thank you in advance.
This post was edited by WarnClub on 04/07/2022 at 03:51 pm.
