I recently reinstalled my 724 loader on my Ford 841 tractor. The pump is relatively new according to the previous owner. The loader worked great at first, probably spent half an hour trying to move stuff on my property a couple weeks ago. Today, it didn't work. At first, it would squeal when I tried to lift the bucket and do almost nothing. I checked the drive shaft, and it was as if it was too short. I could engage it in the engine, but it would appear to be almost off the pump. And then when I started the engine, it would either rumble and make clicking noise or nothing, as the shaft became disconnected from the engine.
There is some wear on the engine end teeth but they don't seem so worn as to prevent engagement.
I can replace the shaft, but if I'm missing something, the problem will just persist.
The pictures I took do not show what I'm describing, but I can get some if needed.
Thank you for your help and advice.
