michdavies
New User
Not sure the year but I have a 580c backhoe that was smoking white and missing eradically. We bought it running like that last spring thinking it needed some injection pump work or something. We've check compression andall cylinders over 400psi, valve adjustment seems good and no bent pushrods and no loss of antifreeze or compression in the radiator. We decided to have the injection pump and injectors tested. They turned out to be bad so we had the pump rebuilt and new injectors. Installed them and still runs the same. I've double checked the pump timing, valve adjustment, and checked the return lines. I'm lost as to were to go from here. Any advice and ideas would be appreciated.
