Sherman power digger
rdjinny
Hi everyone, I need help identifying what the tee handle on the left of pic is forehand how it's supposed to be operated.
I can push it in and out without any resistance, and can also rotate left and right without any resistance, I don't have a clue how it's supposed to be operated, can someone enlighten me?
Thanks in advance
Rick
(quoted from post at 06:59:39 03/04/22) Hi everyone, I need help identifying what the tee handle on the left of pic is forehand how it's supposed to be operated.
Thanks in advance
Rick
Appears to be a diverter valve for a function, outriggers/stabilizers?. Where do the hoses go? Does it allow operation of the outriggers with the same valve as another function? Some of the units having a 4 spool control valve were set up that way.
Ill have to check it out as far as the lines go, I completed install and began moving a lever and major leak near relief valve area might be a nipple crack thrd.
(quoted from post at 08:15:30 03/04/22) Ill have to check it out as far as the lines go, I completed install and began moving a lever and major leak near relief valve area might be a nipple crack thrd.
This has been posted before. There are some Sherman Power Digger manuals over in the N Tractor Club website library you can access. There might be something there that will help you.
(quoted from post at 08:34:30 03/04/22) I looked and couldnt find anything like this particular part
Hoping someone knows what and how
You can't go by looks alone. It may perform the same function as another, but look different because it is a different manufacturer, earlier or later version, etc. We can't see how it is connected. Make a diagram of the plumbing and where each hose goes, that will help confirm what it does, then post a picture of your diagram.
(quoted from post at 05:58:08 03/04/22)
I will do that today and repost
thanks
