1973 Cat D5 Injector pump removal
jjamna
Trying to remove an injector pump but no luck. Looks like all bolts are removed and it is binding on the shaft. Are there any tricks to removing one? And where can you buy reprinted service manuals on cats. Dealer said manual was no longer available.
It act's like the shaft is bound up on it. Reason for pulling. Throttle only goes from idle to maybe 1/4 throttle. That is all.
yes--they are expensive--the manual for my 941 B was around $300--it has the 3304 engine which may be the same as yours? its a 4 cyl
The pump has dowels in the mounting flange, make sure all the retaining bolts between the flange and accessory drive housing are removed, the pump drive is an offset tang and should come straight off it does not require timing as it only fits the one way, you have checked the fuel flow is good, the sediment bowl clean and the fuel filter clean, the gauge reading full pressure.
Good luck
AJ
