Hello so I have an old D6-8u that has been in my family for 3 generations serial number 8u-8981. The other day I headed out to move some gravel I took off and turned left tracked about 200 yards engaged the right made the turn and felt like a pop in the steering clutch. Now I have no power to the right track unless I run the cat at low power it will turn. If I pull the left clutch the cat stops. I did discover that the plugs have been out of the steering clutch compartment and there was a lot of gunk. I opened the inspection plates and cleaned with solvent then ran filled the compartments up with solvent and pulled the levers and brakes like the manual suggested. The left clutch feels better but the right is still the same. Where is the next place to start?
Thanks
Thanks
