Any folks on here own a Hough H65C payloader?
Hi my name is Jim and I purchased a very well taken care off Hough IH H65C payloader . I love this thing perfect piece of equipment to my property I would love to hear suggestions to manuals for this service,maintain everything,parts and all that and maybe some places to order parts or cross reference parts. Thanks in advance for the add to this forum and for any help .
Off subject first time ever driving a articulated payloader actually firs time operating a payload/loader I moved snowbanks today so dang cool . How do I add pictures to post been a while since I have been in the forum type format .
I think that I may have a operators manual, I am unable to locate it this minute.
send me a message for when I am able to locate it so that I can contact you .
email is open .
(quoted from post at 18:22:15 02/18/22) I think that I may have a operators manual, I am unable to locate it this minute.
email is open .
Hi thanks I just ordered a users manual and parts and ]service manual from YT
The 65 c could have several diffrent engines. What engine does your have? Where are you located.
Just a few in general tips;
If yours has the 5 piece wheel rims they have a tendency of going flat when it gets real cold out.
Mine can go 10 months and not loose a pound of air, after a few days of minus 30 I can wake up to 1-4 flat tires.
I have a couple of air over hydraulic 20 ton jacks that I put under the back axle when cold weather is in the forecast.
A set of chains on the front wheels does wonders, I keep mine on year round.
Chains are expensive but not as expensive as getting big equipment out to pull you out not if but when you get stuck.
Grease is cheap, pins and bushings are not, don't be shy when greasing it.
The machine probably seems huge in your mind right now, that will change once you get some seat time on it and you will find more and more uses for it.
This loader has the international IH D-407 when it runs it runs great have starter issues replaced solinoid on starter turn over great for about a minute then now just clicks (sigh) I knew it had starter problems when I bought it.
