Cat d6 9u hydraulic oil
mikewood869
Anyone know if I could get away with using TSC utf or would that be too light weight or if I need to dump in 90w or 85w 140?
I have always used hydraulic oil in my machines--it has anti foaming and anti wear additives--you can get different weight oil depending on the ISO number---32 is about 10w and 46 is about 15w---which is what i use
I thought your machine was a cable machine.Where are the hydraulics on it? Do you mean transmission oil? I thought the transmission
used gear oil and the wet clutch used 10W.
