I have the opportunity to get a TD9 that has been sitting 4 years since the last time it was running. However, it was uncovered and water is in the oil and the engine appears to be stuck. How would I get the 3rd valve open in order to put acetone and transmission fluid into the cylinders?
Would I do any damage putting a new battery and cracking it over.
I know it is going to be a work in progress, but would like to tackle it. I am trying to avoid pulling the head. When it was running last. it was pull started and run real strong. I feel confident that if I can get acetone and transmission fluid into the cylinders it will break free.
Any suggestions or direction is appreciated.
